KMB59
- SSD3900J00WW
- GE
- More than 10 years
GE model SSD3900J00WW stopped draining. S/N indicates manufactured July 2004. I attempted to troubleshoot. I cleaned the center and back filters; these were not really obstructed by anything. The gasket on the piston & nut assembly looks worn. After cleaning I removed front panel and cycled it a few times. When it gets to the drain cycle, the drain solenoid clacks loudly down but instantly returns to the up position. It moves up and down easily when I did it manually. I did not detect that the drain pump ever really ran. The solenoid just clacks down and then instantly up again, other than that nothing happens. After it had been on for a while trying to cycle the drain pump, I attempted to spin the drain motor with my fingertip, and burned my finger. The drain motor was too hot to touch. I did not detect any burned wires or scorching anywhere under there though. Then I used a screwdriver to spin the motor a little and it didn't appear to be seized up.
I removed the piston/nut assembly and solenoid, thinking I'd at least replace those. But is the drain motor supposed to be that hot? Is the solenoid not staying down actually the source of the problem, or would a failed drain pump cause the solenoid to react like that?
Other info: I have not pulled the machine out yet. It is not adjacent to a sink so it is plumbed atypically. The supply line is copper, runs up from the floor at the back, and is nutted to the water valve. The shut off valve is across the kitchen adjacent to the sink shut off. The drain tube goes into the floor after presumably looping up behind the machine (but I can't see behind there yet). I don't think there is any air gap. I haven't pulled it out to see if there are any obstructions in the drain parts themselves.
Should I start with replacing the solenoid, or is it the motor?
Thanks for any advice.
