GE dishwasher will not fill
Stephen_F
St. Louis, MO
GSD2000
Water enters the washer...barely. I've been told it could be calcification on the inlet screen, or a bad pump. I don't mind checking these things...if I had a diagram of the machine.
What are the most likely causes on this model and where do I find a diagram? Thank you.
jackofalltrades
NY
Water Inlet Valve (part #3310) from RepairClinic.com
Take off the panel at the bottom of the dishwasher ( 4 screws) . You will then see the inlet valve on the left side. Take it out and check the inlet screen by taking off the four screws that hold the "L" bracket to the blue plastic body of the valve (the "L" bracket is on the right side of the valve as pictured in the link above)
PS- take note of how the valve comes apart so you can put it back together properly.Also make sure to turn off water supply to dishwasher before starting. If in doubt just install a new valve. The one in the link above is the one you need
