GE Double In-Wall Oven #JTP35SP1SS Door Lock Flashes
Dakine
Colorado
JTP35SP1SS
Working on a GE double oven that the upper oven flashes "Locked Door" in red wording after 40 mins of use on bake. The lower oven works fine with no issues.
Notes: recently replaced the control board 1 week ago. I've tested all components with a ohm meter to be function ok. Beginning to think the door latch assembly needs replacing but not sure how to confirm this???
Any help on this is greatly appreciated as I don't want to have to replace the oven just yet.
Dru
Hi Dru,
I couldn't locate the tech. data sheet or service manual for this model, but Rick helped another person with this problem here:
You can try that and see if that solves it.
Dakine
Colorado
Hi Jake!
Sorry for the delayed response on this but I tried replacing the door locking mechanism and it still didn't cure the issue. The oven works and will heat up to a set temp but after 40 or so mins the door locks and it flashes "Door Lock" on the display. It is what it is on this one 🤷🏾‍♂️
Thanks bigbuck!
Ok @Dakine on the tech. data sheet bigbuck posted look under ERC FAILURE CODES and do what it says to do to pull the error code/codes and see what you get.
