GE Electric Dryer GTX18ESSJ0WW overheats within 2 minutes of being turned on
Richm22
Chicago
GTX18ESSJ0WW
I have this dryer, it overheats within 2 minutes of being turned on. When it turns off it will not restart for about 3-5 minutes. Then once restarted it works as it should. I took a guess and replaced the cycling thermostat and the high limit thermostat. It does also have a safety thermostat that i did not replace yet. I also removed the exhaust and made sure it was clear. Is there any advice on a way to test before spending any more on guesses? Thanks for any advice.
What exactly do you mean by that? Is the exhaust air temperature higher than normal or is the cabinet top getting hot?
If the latter, check your dryer venting all the way from the dryer to the outdoors.
LINK > Dryer Venting Tips
A blocked or partially obstructed vent will reduce air flow causing the cabinet to get hot and would likely trip the safety thermostat as a safety precaution before the dryer catches on fire
Richm22
Chicago
I mean it thinks its overheating but its not even warm yet. It trips something that makes it shut off for 2-3 minutes. It does the same thing on air fluff. not even using heat. Even with no heat at all it shuts off in under 2 minutes. After it shuts off for the first time its good the second time for as long as its set for
If the dryer is not overheating but just the motor shuts off for some period of time, the motor may be cutting out on its internal overload protector until it resets again after non-use.
Most commonly the motor is defective and needs to be replaced. It probably has bad motor bearings.
LINK > GE GTX18ESSJ0WW Dryer Motor
It's a very common failure on dryers of all makes unfortunately.
Richm22
Chicago
ok. After it shuts off if you listen there is a click inside the dryer that sounds like a switch or relay. Once it clicks it restarts and will run its cycle
Try to isolate where the sound is coming from and report back.
Dan O
