omartian
- GFD28GSLBSS
- GE
- 1-5 years
Hi guys-
I have a french door GE GFD28GSLBSS fridge that has not been cooling well for the last 2 days.
i noticed that the cheese drawer and lower racks were cooler towards the bottom of the fridge, but the top row was almost room temp.
I don't have anything blocking the temp sensor at the top of the fridge and the side ports are clear of obstruction. It's not overly dusty under the fridge but i cleaned it up. i can still hear the fan running and as of right now the freezer is working. Within the fridge, the top vent isn't blowing cool air, but the bottom one is.
In the back, there was a ton of dust. so i took a toothbrush and my shop vac and cleaned it out.
seen here before and after:
I noticed that the drain tube valve was a little gross so i took a pipe cleaner to it to make sure it was free of obstructions and left everything last night. I can also feel the compressor humming along as well.
When i checked today, it's still not cooling effectively. Have the temp set to 37 but it's definitely not there.
I took the fridge apart from the inside to look at the Evap tube and the trough drain and it was slightly frozen but the drain was open.
When i looked behind the fridge an hour later, i couldn't hear the fan, so i looked behind the fridge and noticed that the drain tube had water in it and was surrounded by some sitting water. i emptied the drain tube again and cleaned up the small amount of sitting water (not sure if this was from me trying to clear out the trough drain), and now the fan is back up.
I used turbo cool yesterday, but am afraid of doing it now due to it speeding up the condensation/icing.
any further suggestions or should i just call a repair guy?
