Jwk4301
- GDF570SSJ2SS
- GE
- 1-5 years
GE - GDF570SSJ2SS. Dishwasher is about 3 years old. A few months ago I noticed a small, seemingly irregular water leak. (I’ve now discovered that the leak appears to be coming from somewhere in the door panel itself, behind the outside cover). The unit then began to occasionally act like it has no power/no lights and the quick fix was to flip the breaker off for a few minutes and once power was reapplied the unit would function normally for a few days before going back to no power/no lights. The last time I tried just turning the breaker off and back on, the unit did not power on and would not function.
I accessed the Service LED on the Main Control Board and it was steady lit. After a short amount of research, I replaced the MCB and after that the unit powered on and functioned properly for one cycle. The unit did leak during this cycle and by the next day it had no power once again. I tried flipping the breaker and after a few times the Service LED finally went from steady to slow flash (1x per 3 seconds).
I have since removed the door and observed the leak to possibly be somewhere in the door between the panels. Does anyone have any ideas as to: #1 Where the leak in the door may be, or how to better determine the location? #2 With the MCB already having been replaced, what should my next step be, other than locating and repairing the leak?
Any advice is much appreciated. Thank you in advance.
