MaintenceGuy656
- GDF620HMJ0ES
- GE
- 1-5 years
I recently purchased an entire appliance set off of someone and before taking the appliances all them were ran and made sure they worked. The dishwasher ran fine, brought it home and placed in the garage while we finished the kitchen. After about a week I went to install the dishwasher. I plugged it and on the door panel it showed 220, but after about 15 minutes it changed to 110. I assumed it would be working, so the next day I loaded the dishwasher wanting to start a load. Closed the door and tried to pushing my cycle and start. The door showed no sign of life, no beeps or green lights or even the time display.
I checked to see if it was plugged in, then the breaker, then if the outlet worked. All of that was fine so I took the kick plate off and checked to see if it was hot at the main board, which it was hot. I then took my no touch electrical tester and followed all the visible wires and they were also all hot. The only wires I could not see were in the door. I then went to this forum site and tried to do everything and anything people were saying. I would unplug the machine and plug it back in to check the led on the main board, it would light up green for about a second and then turn off. After looking it up on the forum and manuals I came to the conclusion that there was no communication between the UI and the main board. So I took the door off and found two broken wires leading to the soap dispenser. I was relieved I had finally found the issue, ordered the new wiring harness. The harness came in, put the machine all back together only to find the same thing. No door lights and a green led for about a second on the main panel.
So today I come here with no idea what to do next, wondering if I need to replace UI or the main board. I feel as if I have tried every diagnostic route possible and have no clear answer. I don't have a multimeter test, could that be my missing diagnostic tool or does the single light for about a second tell me something else I've overlooked?
I would appreciate any help or theories I can get before I go and order a lot more parts and spend any unnecessary money. Thank you in advance!
