FIXED GE GDF620HMJ2ES display and buttons not working
Jared9
Vermont
GDF620HMJ2ES
Hello,
4 year old dishwasher. For the last few months it’s started to “wake up” and beep randomly. Over time, maybe week or so, it does it more often until it quits altogether. 12 or 20 minute reset of the breaker and it comes back to life. But still randomly wakes up until it quits again. I’ve searched all over here and found out a lot. My service led is blinking fast, probably 2 times a second. What should I look at replacing?
You need the UI Board.
Here's the UI(user interface) Board for your model you can order: WD21X23462 Kit Svc Ui Top Logic
Another member had this exact same problem and the new UI Board fixed it:
Jared9
Vermont
Excellent. I have one ordered. Why I wasn’t convinced it was the UI was because everyone else’s status led seemed to be solid.
Thank you very much.
Glad to help Jared.
"NOTE--->When replacing UI Boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly"
Jared9
Vermont
Yes I saw the jumper piece you talked about before. What do you make of my status led light blink sequence?
Nothing, because I had a customer with this same dishwasher and his was running great but no lights ever came on, and I knew that was the UI Board causing the problem, sure enough after I replaced his UI Board it fixed it.
Anytime you get odd behave with the UI Board but the dishwasher is still running fine, then your main control board is fine.
Jared9
Vermont
Sounds great. Thank you again for all the help. Just waiting on the UI to get here.
Ok Jared, keep us posted.
Jared9
Vermont
trying to get ready for install. Part should be here in the next couple of days. What am I looking at as far as taking door off and swapping UIs??
Watch this video:
On some models the hinges at the bottom are on the 'outside' of the outer door. On your door, they may be on the inside.
On some models there are 4 extra T25 screws that hold the door in on.
Here's the service manual instructions for your exact model:
You will need to remove the whole door, then separate the door, then remove the front control console, to replace the UI Board.
Here's the service manual for your model: https://drive.google.com/open?id=1XTOXM0wA0UJEuucW0deIni17sMPtDGtD
Page 26 Door Removal
Page 28 Separate Door
Page 29 Front Control Console Removal
Page 30 UI Removal
NOTE--->When replacing UI control boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly.
Jared9
Vermont
Okay cool. Watching the video from before, the guy just unhooks the door cables from the hinges. In that manual they have you insert an Allen key in a hole to lock the hinge. Leaving the hinge on the dishwasher versus on the door and just unscrewing them. Seems the video method is much quicker.
Yes, I agree!
Jared9
Vermont
Hey Jake,
UI finally got here! Set the jumpers according to instructions.Used the video method and had the door off and separated in a matter of a few minutes. Swapped UI and right back together. Power on and everything looks to be working perfectly. Will run a cycle today and watch to make sure the UI doesn’t randomly turn on.
Thanks for all your help. Super easy fix!
Jared
Excellent Jared, glad to hear the new UI Board fixed it.(y)
Perfect! Glad to hear that Jared!
