FIXED GE GDF620HMJ2ES is dead, no lights. Has power. Main control board has steady green light
aho
Mn
GDF620HMJ2ES
GE GDF620HMJ2ES is dead, no lights. Has power. Main control board has steady green light.
aho
Mn
Tried resetting the CSM - nothing happened. No lights or sounds. Door latch appears to be ok. I tried following the procedures to test the main control board, but can't seen to find the pins it tells you to check?
Ok, If the SERVICE LED is SOLID GREEN, then its likely a bad UI(User Interface).
Here's the UI(user interface) for your model: WD21X23462 Kit Svc Ui Top Logic
You can verify that will a multimeter. The UI operational voltage is output from the main control on connector J722 pin 2 black/green to pin 5 yellow/black. If 13.5 Volts DC is NOT there, replace the main control.
If 13.5 Volts DC is there, replace the UI.
aho
Mn
I am trying to check stuff that does not require me to remove the door, but also don't want to order a UI board and or MC board if 1 of them is not bad.
J722 is on the main control board, get a flashlight or droplight to see it better.:)
aho
Mn
I have a pair of glasses and a magnifying lens... Lol.can you give me an area to search? Like lower right... Etc
aho
Mn
I have it out and looking again...
It's the connector where the door wire harness connects to the main control board.
aho
Mn
So the white plug.... Says J711 above it.
aho
Mn
Also, am I testing the pins on the bottom of the metal tray that holds the MC board? Where the door harness plugs into....
aho
Mn
There it is, the white one above the ethernet port.:)
aho
Mn
Sorry for all the ?'s, but I'm guessing the board needs to be plugged into the power harness? Do the rest of the harnesses need to be plugged into to test... There's not much room... And do u put my meter thing on 2m ?
aho
Mn
Sorry again, never used this multimeter... But I'm trying :)
aho
Mn
Switched it to this setting? V~?
No, that's AC.
Put your meter on V with the straight line and dots underneath the straight line.
Put it on 20.
Yes, you need to connect the 120 volt connector up to the board, that should be all.
aho
Mn
So I'm guessing the MC board is ok and I need a UI?
