GE GDP615 Dishwasher UI misbehaving and Orange light flashing continuously
raystein
San Diego
GDP615HSM0SS
I'm trying to decide if I should change the UI board or main board on my 2018 GE GDP615HSM0SS Dishwasher. I read the Service Manual, but I'm still baffled and would appreciate any suggestions anyone might have. I have tried the obvious things like hold start, reset, unplug/wait10minutes/replug, but with no help. Note, the main board LED is flashing rapidly, but I see this is not interesting on this model.
2 Days ago: Door mounted LED would continuously blink orange and start LED green. On entering CEM mode all LEDS flash (note, door is closed and door switch continuity verified ok) followed by a "5" posting on the 7-segment-display for a few seconds. My guess is the 5 is related to my non-functioning detergent cup - I'm extrapolating this from the fault codes on page 45 of the service manual? I next entered Service Mode, and none of the tests did anything (however, the "normal" led flashed the correct number of times when cycling through the 6 different tests).
Today (Different behavior). Control UI LEDs (and 7-segment-display) act as if all is ok after a power cycle, but the control buttons either partially work or sometimes not work at all right now.
I'm leaning towards replacing the main board, but thinking about ordering a UI board also. Any Suggestions?
Thanks, Ray
Hi Ray,
I didn't know you started a new thread, so I'll just copy and paste what I said in that other thread you posted in.:)
That tells me its the UI Board.:)
Here's the UI Board for your model GDP615HSM0SS you can order:
Here's the service manual for your model: https://drive.google.com/file/d/1csheGsbSmPFRON5ThkhhwfvZ6saWoxHc/view?usp=sharing It shows you how to replace it.
raystein
San Diego
Thanks so much :) . I'm assuming the UI board will come with Installation Instructions for setting the Personality Jumpers?
You bet it will.:)
