Bdogggut34
- GDT580SSF0SS
I have a GE GDT580SSF0SS dishwasher. It was here when we purchased the house and worked just fine for 3 years we have been here. However sometime in the last 3 months the heater element stopped coming on. Choosing all options including heated dry, the element is cool to the touch when opened immediately or during the cycle and dishes no longer dry.
Here is what I have done:
1. Replaced the heat element even though the other one seemed to test ok. I have checked all wiring all the way to the plug going into the control board and I read 16.2 ohms at that plug. I did a negative check and removed a wire on the element and it drops out so I know I have continuity.
2. Replaced the control board. Figured this was the issue then however a new board and no changes.
3. Found the paper on how to run diagnostic so ran it into service mode. Was able to get the pump to come on, fan, fill up and drain however when running the mode to ‘turn heat element on for 2 mintues’ it stays cool to the touch.
I understand and see there is the thermal switch that rests up against the bottom of the tub. Not sure how to test this but as mentioned I have 16.2 ohms at the plug to the board so I know there is continuity through it. Not sure how it works but there is a small button on the back of it that stays down and can be pushed up. I’ve check it both ways and even when you push it up the ohms and continuity stay the same.
I’m out of ideas at this point, anyone have any clue what to do next?
