FIXED GE GDT695SSJ0SS dishwasher - Did not finish all wash cycles, can't restart
LANshake
earth
GDT695SSJOSS
GE GDT695SSJ0SS did not finish all cycles, missed rinse and standing water in tub.
Starting a new wash cycle, getting 3 beeps and flashing orange led on door, just like the door not being shut.
Last month with the same issue, disconnecting power for 20 minutes got it working again.
When entering Consumer Error Mode, all LED's flash when door is open or closed.
When in Service Mode, can not start any functions.
Will be checking the LED on the control board, any other suggestions ?
Hi, Yes, check your machine control board STATUS LED, Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
--->Here's the machine control board for your model: WD21X24901 Machine Control
To view the STATUS LED, remove the lower access panel of your dishwasher. You DO NOT have remove the control board from its metal casing when you view the STATUS LED.
When you have that panel lowered down turn the breaker back ON to your dishwasher. When viewing it leave all the electrical connectors to it plugged in.
LANshake
earth
I check the machine control board STATUS LED, and found it - STEADY OFF.
Also tried removing the board connectors and reseating, no luck.
The door latch switch checks out OK with a meter.
When gaining access to the machine control board, one of the AC wires came loose after removing the Junction box cover.
Checking the connection to the appliance power cord, I found the Hot and Neutral reversed.
Oh ok, so it was Reversed polarity?
Did you fix it and its working good now?
LANshake
earth
Correcting the Hot and Neutral connections did not fix the problem.
With power connected, the machine control board STATUS LED shows - STEADY OFF.
From reading other posts, replacing the Machine Control Board should fix things.
Correct, STEADY OFF indicates the main control board is the culprit.
I posted the link to it in post #2 above.
LANshake
earth
Replaced the machine control board, dishwasher working again.
Thank You for your help Jake.
Excellent LANshake, glad to hear the new machine control board fixed it.(y)
