FIXED GE GDT695SSJ0SS Won't Start, flashing with 815 error code
paulbram
Seattle
GDT695SSJ0SS
Hello,
My GE GDT695SSJ0SS flashes for 10 seconds with an 815 error code. It really appears like the door is making a solid connection however.
I checked the control board and I'm not seeing any green LED's flashing at all. Does this mean I should replace my control board? Or is it possible my latch is bad??
I also tried to run through some of the tests in service mode, but it didn't seem to do anything as I cycled through the tests other than a single beep.
Hi Paul,
Yes, if the Service LED is STEADY OFF the tech. data sheet says check to make sure you have 120 volts going to it, if so and the Service LED is still STEADY OFF it says replace the main control board.
--->Here's the main control board for your model you can order: WD21X24901 Machine Control
paulbram
Seattle
Hello, just an update. I replaced the main control board and it seems to have fixed the problem! Thanks for your help!
Excellent Paul, glad to hear the new main control board fixed it. (y)
