When the dishwasher does not fill when its suppose to fill, Stay with the machine listen for water coming into the machine.
If you hear no water entering, you will need a
multimeter to check for 13.5 DC Volts at the water inlet valve electrical connectors.
WD15X24213 Water Inlet Valve
If you DO NOT get 13.5 DC Volts when it should be filling, then ohm test the float switch(while the button on it is pushed in) for continuity.
Here's the float switch for your model:
Float Switch WD21X23498
Its in-stock here if you need it:
This is a flood switch that is a part of many dishwashers made by GE. The flood switch is the component that ensures the correct amount of water is used during a cycle. It is an important component that can wear out or become damaged. If this occurs, the dishwasher might overfill and overflow or...
click.linksynergy.com
Here's the service manual for your model:
https://drive.google.com/file/d/1M-G9W3HiaYnihdB5Cy-jfSPoVf8DZ7j7/view?usp=sharing Page 51 tells you how to access the float switch. Make sure you disconnect power to your dishwasher before ohm testing it.
