- GFE28HGHEBB
- GE
- 1-5 years
So, I have the GE fridge and it has been working well for years. Now, from time to time the fridge temperature gets warm, while freezer remains frozen.
With temperature data logger, you can see how it varies (when set to 34). Sometimes for days on end temperature rises and remains above safe levels.
I've gotten into the diagnostic mode, disassembled the back and verified that all of the fans work. Coil appears clean and clear of ice.
Green graph is humidity, black is temperature. Temperature units on the left, humidity on the right.
Large spikes with slow die off, such as one at 14:00, are likely from us opening the door to use the fridge.
What could be failing? What diagnostic test can I be checking to verify proper operation?
Thank you for your time.
