Mike63334
- GNE27JSMAFSS
- GE
- 1-5 years
Hi, I just purchased this refrigerator over the weekend to replace my Samsung that had a leak in the sealed system. I got this one for $100 and figured it was worth fixing since the compressor runs fine and the freezer cools as it should. The customer said they had it diagnosed and the tech said it needed the evaporator fan.
They chose to do the repair themselves, but after they replaced the fan, it still wouldn't run. Upon disassembling the freezer section I noticed that the blades wouldn't spin by hand on the new fan they installed. The black wiring harness was improperly routed and was against one of the blades of the fan. After taking care of that I held the door switches all closed and the fan still would not run.
I also noticed the part that opens and closes to control how much air goes into the fridge section was totally closed. Not sure if that opens after the fan starts running? I want to check for voltage going to the fan to see if the new fan motor failed from being in a bind or if there is still another issue. My question is, how much voltage should be on the Yellow wire? I know the rpm, common, and 13v wires, but the tech bulletin I have doesn't show the voltage that should be on the yellow wire.
Also I noticed that the green led is steadily blinking on the control board. Not sure if that indicates a specific error on this model or if it blinks during normal operation. All I have is a 2 page schematic. If someone could send me the service manual I would greatly appreciate it.
Thanks in advance,
Mike
Thanks in advance,
Mike
