tb12goat
- GSS25LGMBWW
- GE
- More than 10 years
Model : GE GSS25LGMBWW
Age: OLD 10+ years
Hi, hope all is well. My GE fridge/freezer is not cooling properly. Freezer hovers between 23-34f degrees, and fridge side hangs in the upper 40's,.
I will post everything i tested below. I'm really hoping someone can help me out here.
Thanks.
Not yet tested:
Defrost thermostat
Motherboard
What i have tested:
-Condenser fan is running and coils are clean.
-Compressor feels warm and i can hear it kick on early in the morning, other than that it's quiet with a low hum.
-No residue under fridge, so i dont think its due to a freon leak.
-Fans on both sides turn on when pressing the door buttons -- how loud should these be when running? Freezer side fan is very quiet.
-Evaporator coils have some ice, not sure if this is considered bad.
Multimeter tests:
FF #1 - 5.71 blue/red stripe
FF #2 - 6.01 yellow
Freezer #1 - 8.36 - red/white
Freezer #2 - 8.68 Freezer blue/white
J2 Pins on control board:
P3/P8 Fan motors +12v (White/double red) 13.70v
P3/P4 Evap fan motor (white/) 13.66v
P3/P5 Condenser fan motor (white/yellow) 12.07v
example:
How would you proceed? Should i try a new rebuilt motherboard?
Thanks.
Age: OLD 10+ years
Thanks.
Not yet tested:
Defrost thermostat
Motherboard
What i have tested:
Multimeter tests:
FF #2 - 6.01 yellow
example:
Thanks.
