- GTDP490ED7WS
- GE
- 6-10 years
We’ve had a GE GTDP490EDWS dryer for about 7 years. Within the last few weeks, we noticed that some loads were taking longer to dry, and it began to shut down mid-cycle after only a few minutes (2-3 min on average). You could hear an audible click and the motor stopped. Give it about another 2-3 minutes, another audible click and then the dryer could be run for a few more minutes. It did not matter if the cycle was sensor or timed. The strangest part was that it would run and finish loads on the off occasion. Continuity checked out on each of the thermostats.
The metal casing was not hot to the touch while it was running and airflow seemed plenty. However, whenever it shut down, the top of the unit towards the back where the heating element is located would get very hot. I assumed that with the blower fan not running anymore from the shut down, it would explain the heat had nowhere else to go.
We moved into a new home within the last few months so I went ahead and cleaned out the vent stack for good measure. I put on a new flexible duct when we moved in. I also cleaned that out as well. None of it was dirty and airflow seems to be plentiful coming out from the vent.
In my mind, all signs pointed to a failed motor from what I could tell so I bought a brand new motor. Unfortunately, it did not fix the issue as it continued to show the same characteristics. You could still hear the audible click.
Today, the dryer will no longer turn on. I assume the thermal fuse has blown. Before I take it apart again, I wanted to see if anyone had any recommendations on something I may have missed initially.
