GE GTW460ASJ6WW can’t spin makes grinding noise
kelsey8703
kentucky
GTW460ASJ6WW
GE Washer GTW460ASJ6WW won’t agitate or spin. Lid lock works fine. I had a heavy load yesterday with a large blanket that kept getting out of balance during spin cycle. Now on the newest load today when it was finished I opened the washer and everything is still wet and not to the sides like it usually is. Not sure what to look for in what parts should be replaced.
Also while we’re at it, it also randomly pours cold water in after a load is finished. I replaced the water valve assembly WH13X26535 and it didn’t fix it. Still let’s off a little stream after every load out of the cold side.
What is the serial number of this machine?
When does that grinding noise come into play? Can you make a video of it? I need to hear it.
When you see it do that immediately unplug the washer from the wall outlet and see if the water stops coming in.
kelsey8703
kentucky
Serial # MH901430G. I ended up taking off the belt housing and found a shredded belt so I’m guessing that’s why it won’t spin/making grinding noises.
The water leak happens when it’s not running at all, load will be complete and clothes out. If you touch your finger to where the water comes into the tub a couple cups of water will pour into the tub. But typically the load is done, clothes still in the tub and then it pours all the water on them and they take forever to dry.
Belts on order so I’ll try to come back and show the water situation once we’re back in operation. Hopefully that fixes it.
Thanks! glad you found the belt was the problem.
Here's the belt for your model in case others need it too:
WH01X24697 Drive Belt
That is very odd, I have not seen that happen before, yes a video of it leaking like that would be very good to see.:)
