- GTW680BSJ5WS
- GE
- 1-5 years
My wife said the last couple of loads have ended with very wet clothes in the tub. I found that water was dripping from the soap dispenser, so they were probably sitting in the tub for a while and being dripped on. I found a couple other posts here about that and ordered a new inlet valve from the link provided. Turning off and on the supply lines, it appeared to be only the hot water dripping. So I left that one off. Wife tried to run a load using cold water setting only but it then came up with an H2O Supply Error. I then turned the hot water back on, restarted and got the error message again. When I get the new inlet valve is that likely to fix this?
