- GUD27ESSJ0WW
- GE
- 1-5 years
I have a GE GUD27ESSJ0WW stackable washer/dryer that I have owned since new. It was installed in 2016. It worked fine until today. It seems to fill and drain correctly but not agitate or spin regardless of the mode I set it to. You can hear the motor running when it is supposed to be agitating or spinning, but the agitator and basket aren't moving.
I started diagnostics mode and the "On" and "Lid Locked" LED lights are solid which according to a Youtube video I watched means some sort of error with the belt? Does this sound correct given the symptoms? I didn't see a service manual posted on the GE site for this model.
Also, I tried to take off the bottom to check the belt and it won't come off. I used a screw driver in the spots where the clips are and it won't budge no matter how much I try. Is there some trick to getting the panel off of these units? Or does this unit for some reason not have a removable panel? Thanks.
