- GUD27ESSJ1WW
- GE
- 6-10 years
I have a GE spacemaker stackable washer and dryer. The dryer ate a metal fastener and in my attempt to locate it (it was causing a grinding sound) I accidentally pulled the drum and bearing out of place. I was able to reinsert the bearing and drum and reassemble the dryer but the hi limit sensor started shutting the entire unit off after running for a few minutes.
I once again took the dryer apart to look for anything I may have knocked out of place and examined the sensors around the heating element. Everything seemed fine so I reassembled the dryer. I ran the dryer without anything in it and it ran fine for about 15 minutes so I added clothes. Now, with clothes in it, the drum stops spinning after 5-10 minutes whole the heating element seems to be running still and it sounds like the cycle is still running minus the dryer drum spinning.
