Spartan S4
- GUD27ESSJ1WW
- GE
- 1-5 years
Hey there
Have a stackable GE GUD27E22J1WW leaking water someplace in the back of unit. We found out about the leak because water was leaking into the condo below. Now we had a new custom drain pan put in years ago and I was shocked that there was water leaking below until I moved the washer and saw that the plumber never sealed the area around the pipe/pan.
So when I did run the washer yesterday, I did start seeing water come out I believe on the drain cycle and it seemed to be coming from someplace under it. Not 100% sure. It definitely was coming from someplace under but I didn't see anything inside the washer drum. Then last night ran some water and drain cycle with the diagnostic testing and looked again.
Inside the washer is dry except the very back left corner.
I didn't even notice this water in the back left till I saw a water dripping reflection on the wall with the lights on and with a flashlight on the back left side and then looked inside and you can barely see it. Also I've watched a few videos and up to the very top on those videos there's a water valve but that's not there on mine (mine seems to be located up top someplace).
There's also a clamp sitting on the bottom of the washer floor.
This is inside a laundry closet so I can't get back behind it but I pulled the intake hoses through the opening and felt no water on them.
Watched a few videos on the error codes and got an overflow and also thermo but I think those were from years ago when we had a few incidents.
I've reset the codes but haven't been able to run the washer till I get the drain pan issue resolved. Custom drain pan for our laundry closet (old condo) and the plumber never sealed the gap between the drain pipe and the cut in the pan. We found out about the leak because water was running out the gap there and into the unit's laundry closet below. Going to have to seal it with silicon and maybe a rubber washer.
Any insights/help greatly appreciated on possible issues here!
