GE Microwave PVM9179SKSS Vent emits high pitched whistle
RJHNY1
New York
PVM9179SKSS
Less than 1 year
Hello all, I bought this GE microwave: https://www.geappliances.com/applia...ion-Over-the-Range-Microwave-Oven-PVM9179SKSS
It actually works great and we love the microwave. However, since it was taken straight out of the box, whenever the vent is turned on, it emits a high pitched whistling sound. It is extremely irritating.
GE sent repair guys twice and they could not figure out the issue. The microwave still made a high pitched whistling sound even when it was sitting on my counter. So it's not coming from my end. The repair guys told me "this is just how it is." If I knew that beforehand, I most certainly would not have bought this microwave. Even then, there is no way that the vent of a microwave should make this sound anyways.
GE is fighting my wife and I in providing a new microwave to see if it makes the same high pitched whistle. Right now, they are sending repair guys for the THIRD time (from an outside company) to evaluate the microwave.
I was wondering if anyone else has had this issue with their microwave. Any advice? It would be extremely difficult to get a different microwave because the house came with a GE profile before and the new one is the same size as the old one, which fits the space perfectly, without having to touch the backsplash to make room for it.
Most microwave hood combinations are the same size designed to fit in the space above the range. The difference is in the mounting. The mounting bracket probably needs to be changed but the bracket comes with different holes to match up with the existing holes (usually).
RJHNY1
New York
Thanks for your response. I was saying that other microwaves may stick out another inch or be another inch or two taller, which would mean it would take up more space over the stove. I'm not sure what that has to do with the mounting brackets?
I guess I was confused by the words "extremely difficult". I was just saying any brand and model will fit in that space. Any brand other than GE you would need to change the mounting bracket.
RJHNY1
New York
Sorry about that, I was talking about the dimensions of the microwave b/c a lot of the other ones are a inch deeper and/or an inch taller. Sticking out another inch will look funny.
