FIXED GE Model GDF520PGJ2WW dishwasher will not start after reset.
jds43232
Columbus, Ohio
GDF520PGJ2WW
Hi everyone. So I have this GE dishwasher that a lot of people seem to have problems with.
After looking online I saw that you are supposed to press the start and select cycle button for five seconds to see what happens. I’m getting 10 flashes and then the lock controls come on. I’m not exactly sure what to do after that to fix the problem, but I have shut the breaker off more than once and nothing fixes it. After doing the start and select cycle button then I push the start button, it just beeps at me and will not do anything.
I at first thought I needed to buy a new control board, but obviously if I’m able to do all the things I just mentioned then I don’t think I need a control board. I replaced the door latch with a new one thinking that was the problem (as I saw online that seems to be the biggest problem) but that didn’t fix it either.
Any help would be greatly appreciated!
jds43232
Columbus, Ohio
After reading more and more online I saw where there’s supposed to be an LED indicator on the board? Is that correct? I see no light on my board while hooked up, but I don’t know if it’s actually supposed to have one.
I also failed to mention in my thread that I can get the display to do different things. When I hold down the start and select cycle buttons it will go into that mode. But then nothing else happens. When I try pressing the start button it gives me a dull beep.
I ordered a new board yesterday so I’m hoping that will fix the issue. As stated before the first thing I replaced was the door latch. Now I will be replacing the board so it’s got to work, right?
Hi, Yes, Check the machine control board STATUS LED (its located underneath the front on the dishwasher). Tell us how many times its flashing in a row, or if its STEADY ON or STEADY OFF.
If its STEADY OFF, that indicates the machine control board is the problem.
Here's the machine control board(under the dishwasher) for your model: WD21X24900C
To view the STATUS LED, remove the lower access panel of your dishwasher. You DO NOT have remove the control board from its metal casing when you view the STATUS LED.
When you have that panel lowered down turn the breaker back ON to your dishwasher. When viewing it leave all the electrical connectors to it plugged in.
jds43232
Columbus, Ohio
Thank you so much for getting back to me. I attached a picture of my board (it’s not a great picture as it was difficult to take). But yea there’s no LED light coming on at all.
It’s odd to me that I’m able to do the “start” and “select cycle” for 5 seconds and get it into status mode, but if that means it’s bad then it’s bad.
I ordered a new board yesterday so it should arrive first of next week.
Ok, then if you don't see it ON or FLASHING, then the machine control board is the problem, if you are getting 120 volts to the machine control board.
Its a little more detailed in this photo of where its located, its labeled Service LED(aka STATUS LED):
Sounds good, let us know how it goes.
jds43232
Columbus, Ohio
Jake, my control board arrived and I got it installed. It works perfectly!! So I’m good to go. It’s funny I didn’t even know about there being an LED light on it because mine wasn’t working. So the information you provided was exactly what I needed. Once the new one came in and I attached it, the LED light flashed showing me the dishwasher was in “maintenance mode” or whatever you call it. I took it out of that mode and she started right up. Thanks again for the help.
Excellent, glad to hear the new machine control board fixed it.(y)
