GE MODEL GTWN4250D1WS - Wash cycle auto repeats...
colton471
virginia
GTWN4250D1WS
Hey yall, this 9 yr old GE washer, model GTWN4250D1WS, keeps repeating wash cycle. On normal wash it fills, washes, and drains fine. Indicator light marks cycle as expected until rinse cycle begins. Once rinse cycle is to begin, indicator light goes back to wash. Unit is fine until it hits rinse cycle. We have to manually select rinse cycle to finish load.
Any and all help is greatly appreciated.
Thanks, Colton
Hi Colton,
The problem is the control board.
WH12X10614 Control Asm
That's very odd, that new board should of fixed it.
I'm attaching your tech. data sheet below, get into FIELD SERVICE MODE and do TEST 4 to check for error codes.
  • TB01-12 GE Top Load Washer Testing Procedures.pdf
colton471
virginia
This was an attempt at remote repair for a family member which failed.
Recommended test did not work, test described in owners manual did not work. Other tests for same model found online did not work. No codes were produced.
Wash cycle completed by manually advancing cycles. Upon completion, grease found on garments.
Unit trashed and replaced without my knowledge.
Thanks, Colton
Got it Colton!
colton471
virginia
My apologies, and thanks. I'm mad the fam was quick to abandon repair and purchase new! Maybe I should have driven the 6.5 hours to do it in person. LMAO!!!
COLTON
No worries, what's done is done.:)
