rascalnd
- WVSR1060A0WW
- GE
- More than 10 years
GE Model # WVSR1060A0WW top load washer will fill, agitate, drain, but it will not spin.
Here is some of the things I have tested/tried:
01. Tested the lid switch. There is no issues with it and it functions as intended.
02. Removed the drain pump. It operates as it should and there are no blockages in either hoses or in the pump.
03. Load pressure tube. It is clear and there are no obstructions where it attaches to the washer tub.
04. Removed the timer knob and outer ring and verified that both are seated and secured onto the timer.
05. I am able to spin the motor pulley easily and without any restrictions.
06. Belt is in good condition and tight.
07. I have reset the machine.
08. I cannot turn the drum by hand.
