Monogram_help
- ZISS360DRAS
- GE
- More than 10 years
First, I want to say that this forum is awesome!!! Thank you!
Over the past few days, I've read and re-read the procedures for testing my monogram not cooling problem... It turns out that the compressor is not running while all fans and lights are working.
Following Rick's guide, I tested the voltage with all wires connected at J15.. I have 5.28v there. Is this enough?
I have 0 volts at the compressor connector with all wires connected. I have 10 ohms between the compressor connectors. Except one was 8ohms. (possibly the probe wasn't fully connecting)
Does the voltage reading mean I most likely have a bad inverter board? If so, what inverter part number should I order? I can't find it even in the troubleshooting guide.
Given the fact that they're pretty pricey, I don't want to order parts again and again...
