FIXED GE Monogram ZE2160SF02 light and turntable stop but still heats
wahlcoman
Phoenix, AZ
ZE2160SF02
Microwave has lights and turntable working. Periodically, when initially starting (after 1 second), light will go off along with the turntable BUT will still heat. When doing this it will make a different low hum noise. Any ideas what to start with? Thanks
Here's the part you need however you might want to price new microwaves first. Countertop microwaves can be purchased for under $50 and up. Remember after the repair everything else is still going to be 10 years old.
Main Control Board WB27X10688
wahlcoman
Phoenix, AZ
Thanks Rick. That's a good point, unfortunately, this unit has a built-in look above an oven with a trim ring. Replacement micro for this application is approx. $600 and may just have to bite the bullet!
