GE Monogram ZFGP21HYASS Water Leaking on Floor and No Ice
Kitchen-Guy
Tulsa, OK
ZFGP21HYASS
I have a GE Monogram ZFGP21HYASS (2011) with a water dispenser inside the refrigerator and ice maker in the freezer. I recently noticed water on the floor coming from under the unit. I changed the water filter; water dispenser works fine, but now the ice maker is not making ice and the refrigerator has started to leak water again. I turned the ice maker off and on again several times, I can hear the ice maker trying to fill, but maybe not enough water is getting to it and it is still leaking.
Any advice would be greatly appreciated!
Sounds like the water line tubing to the ice maker has cracked/broken, thus the water on the floor and not much water in the ice maker.
The ice maker water line tubing is usually 1/4".
Then all you'd need is the tubing and the john guest union connector. Home Depot or Lowes sells that tubing and 1/4" John Guest union connector.
