FIXED GE PFE29PSDASS Not Cooling, Troubleshooting Board Voltage
Mr Ed 123
Akron
PFE29PSDASS
GE Refrigerator model #PFE29PSDASS stopped cooling. The compressor fan runs, but there is not vibration from the compressor. I have noticed that if I plug it in after sitting unplugged I have a quick little blip (2-3 secs) of vibration from the compressor. I did quite a bit of searching around, and followed the troubleshooting from the below thread regarding the voltages.
My results with the signal wires to the inverter board connected:
Signal wires at the J9 connector pins 7 and 8 = 1.5-2.8VDC
Signal wires at the inverter board = 1.9-2.7VDC
AC Input wires to inverter board = 123VAC
My results with the signal wires to the inverter board disconnected:
Signal wires at the disconnected connector = 3.5-4.9VDC
The little few second rumble of the compressor shortly after plugging in got me curious and so I set my DMM on two of the posts during this time and found a quick voltage reading peaking at about 50VAC, and then quickly tapering off to insignificance.
I'm a bit confused at the "2-3 VDC effective voltage" and the "4-6VDC measured voltage" as the shown in the service guide. I thought that "effective voltage" would be the same as the measured voltage. Which if that was the case then I am seeing an appropriate amount of voltage to the inverter board. Based on the previous posts it seems like it should be the main board, but after talking with some more electrically savvy friends they are confused by the description in the service guide.
I appreciate any help.
Yes, I agree the service guide is a bit confusing on that to me as well.
Per that other thread you posted, it turned out to be the inverter board that was the culprit, your model uses the same one:
Does your inverter board smell hot like his did in that thread? Unplug the refrigerator and look for any burnt components on that inverter board.
Mr Ed 123
Akron
I removed the inverter board and there is no smell of burnt components. I do not see any glaring burnt spots, just a general "brownness" over the board.
Ok, then it must be a bad inverter board, your voltages look within voltage range.
Mr Ed 123
Akron
I just wanted to follow up and say that the new inverter board did indeed solve the issue. Thanks again for the help!
I bought the inverter board from the link and shipping was super fast!
Excellent, glad to hear the new inverter board fixed it.(y)
