GE portable ac APFO06JASWG1 not cold
pac.attack76
Arkansas
APFO06JASWG1
Turns on and here compressor start and run but not cold and no heat at exhaust. Have it turned to 61 F.
That's usually a sealed system issue.
Check your owners manual warranty to see if the sealed system is covered by a extended limited warranty.
I picked this up from a guy that was cleaning out his garage and he said it worked last time he used it.im guessing at some point, it was laid down
Got it!
Not much you can do then, sorry. Unless your a sealed system tech.?
