- GSD2230Z02WW
- GE
- More than 10 years
I couldn't find a tag, so I'm not sure of the exact model. It's an older one with a rotary cycle selector and four push-buttons on the front for scrub/normal and heated dry on/off, no lights or displays. The float switch isn't the mushroom type, but is covered and protected by a bolt and bracket going to the heating element.
We noticed an undissolved detergent pack in the basin after a load, ran another through, and found the new pack also undissolved. The water pressure seems fine and the flow looked good when I started a cycle with the door open (overriding the latch). I disconnected the inlet hose and cleaned out the screen, made sure there were no blockages, and hooked it all back up. Put some cups right-side up in both racks and ran a cycle. The top cups had no water and the bottom ones were maybe 1/4 full. With the door open and me holding a hand over the center of the spray arm to catch the water, the center column didn't feel like it was getting enough pressure to raise all the way. But there wasn't much water in, either.
I'm getting about 800 Ohms at the inlet valve (within spec), continuity at the float switch is fine, the float travels freely, and the arm is clear of blockages. I cleaned out the drain filter and moved what I assume is the chopper (little wire stub sticking into the filter, I can move it in a circle and it's moving freely). I also removed the spray arms and put a large glass bowl over the sump so I could start a cycle with the door open and see exactly how much of the basin was filling, but quite a bit of water came out from under the machine when I tried. I'm still not clear as to what happened there. After I buttoned it back up and started it again, no signs of a leak.
I'm at a loss as to what to check next if the float switch and inlet valve are testing OK. I have not removed the valve to check the solenoid, but that's going to involve building a battery pack and the flow looked strong. Could this still be the issue? What else should I be checking? Thanks!
Added model number
Added model number
