cam4x42001
- PDT715SYN0FS
- GE
- 1-5 years
Hello everyone. I have a 1.5 year old GE Profile dishwasher PDT715SYN0FS that has issues!! Pick a cycle any cycle and start. With in 2 to 30-40 minutes it will stop. The power does not stop. It just resets itself and looking at it looks like you didn't start it. I picked a different cycle and start. And again it will just stop. I thought maybe the door wasn't closed all the way but it latched as should. I checked the drain and disposal and everything was good there.
I filled the bottom up with water and started it and it would drain every drop. So moving on. Tried it again. And same thing. So moved to taking the filter out and the last of the water in the bottom where the filter sets in. Nothing in there. Pulled the racks out and the spinners to check them. All clean. Removed the bottom where the bottom spinner sets on by removing the screws. Was a little dirty but not bad. Checked all the tubes that move water throughout the inside and those are clean.
Put things back together and tried it again. Still no change. Did a hard restart by shutting off the breaker to the dishwasher for a min or so. When it came back on it said h20. Ok so checking water inlet pressure and for blocks. Nope all clear and good house pressure. Took a couple restarts but the h20 went away. You can hear it drain, you can hear the water spraying inside the tub. There is no leaks, there is no noise, there is no smell (electrical, plastic, burning, or anything), there is nothing but storing mid cycle to say it has an issue.
I can not find a darn thing about this DW online other then basic troubleshooting. I found something saying that the vent fan could make it stop and the display go blank. I should say that the front display is what will say washing/clean/drying, and on the top has the touch buttons and the timer. When it stops the front display is what goes blank. At any rate I read that the vent fan will make it stop mid cycle and the display will be blank. Ok sounds like my issue. So pulled the door and took it apart.
When I got into the vent fan the rubber gasket around the fan was half out and pressed against the fan a bit. I figured that had to be the issue. I took the fan out and replaced the gasket the way it should have been and put things back together and tried this again. With hope this would work I proceeded. I started the DW and the first time it stopped within minutes. Started it again as I figured I had just had it empty water and everything so naturally it would stop. It ran and kept going.
It went 59 minutes with 1 minute left I was standing there and it stopped. Ugh did it again and it finished and displayed clean. I now have it running again with an added option of heat dry to see what it does. So far so good. I could use some help. I'm not taking it to be fixed when I can do it myself and I'm not buying another 1000$ DW!
Added complete model number
