FIXED GE Profile Dishwasher PDW7300N15CC Won't Start
glad4
US
PDW7300N15CC
Salutations,
My GE Profile dishwasher from 2007 stopped functioning recently. Every button on the keypad functions, the display screen functions, the door latch seems to function and it still beeps when latched. I can enter service/diagnostic mode, and some numbers show up on the display when I press 1L/2L/1R/2R/4R, however, none of the functions engage; the buttons beep, and there is a audible "click" of a relay, but nothing else.
I purchased a said-to-be good control board on ebay for $15 and installed it. Same problem, no change. I also disassembled the entire drain system and cleaned out all components. Also, no change.
Any advice or guidance is greatly appreciated. Thanks!
Here's the service manual: https://drive.google.com/file/d/0Bz...are_link&resourcekey=0-9ZKjXDoatOE778A4O_DGZA
Page 16 Door Interlock Switch, are you absolutely sure your door switch ohms good?
Here's the door switch for your model, if needed:
Door Switch WD21X10169
Also check these parts below related to the door switch.
Here's the door handle actuator for your model:
WD13X10045 Handle Actuator
There is a "HOW TO" video in the part link.
Here's the door switch spring for your model:
WD03X10026 Spring Plunger
Other that that, the service manual does not say how to test the control module to verify you bought a good control module.
Thank you for the reply. Door switch was visibly melted, new one solved the problem.
Glad to hear the new door switch fixed it.(y)
