GE Profile Microwave PEB2060SM1SS - everything works except no heat !
swuser
MD
PEB2060SM1SS
This GE Profile PEB2060SM1SS microwave is about 8 years old. It powers up, runs, etc, but does not heat. Here are troubleshooting results, hoping someone can help since all test results pass (I think).
Diode
- connected a 9V battery, showed approx. 5.6v
Transformer (6170W1D091P0)
- primary terminals, 0.5-0.4 ohm
- secondary terminal to ground, 85.7 ohm
- two windings, 0.3 ohm
- no shorts from any terminal to body
Magnetron (LG 2M246)
- two terminals, 0.3 ohm
- no short terminals to body
Capactior
- 1.06 uF
I am not able to figure out if any of these components are bad, any suggestions will be greatly appreciated.
swuser
MD
Just checked, voltage coming into primary is 0 !! What can I check next?
swuser
MD
Sorry it was 0v with microwave not running. In cook mode, it shows 120v.
Like it should be without anything running.
Good, at least the unit and board is calling for cooking to happen.
Time to see if it is creating high voltage or not.
