GE Profile Model JE1860GB001 Operation is intermittent
valleyma
Central California
JE1860GB001
Operation is intermittent; sometimes works normally. Other times, e.g., when trying to boil a cup of water, the sound will tell that it is on but then goes silent and no hot water in cup.
Is the magnetron (not available is AppliancePartsPros response), door latch, other the likely cause for intermittent operation of this 17 year old machine?
So you're saying you can hear the mag tube humm when it's working normally and when it's not you don't hear the humm. That's a common problem with all microwaves but can be caused by just about anything. It's usually caused when power is lost to the high voltage transformer. That can be a door switch or a control board relay. Intermittent problems are the hardest to diagnose because you usually need to catch it in the act. Next time it doesn't work see if the transformer is getting 120 VAC.
