Treeman1
- PDS22SBSARSS
- GE
- More than 10 years
Our GE Profile Refrigerator will not cool, both the freezer and fridge compartment. The condenser and the circulating fans both run. The settings read room temperatures, when set for colder the new settings show up, "0" and "34" but the green "Set" LEDs do not remain lit and both return to current temperatures of 69 +. I removed the back panel, the compressor is not running.
Tested the starter relay and appeared to be ok, but had a burnt smell to it, so I replaced it. Also replaced the startup capacitor. But compressor still does not run. When plugged in and unplugged you can hear the motherboard click to turn and off.
No signs of anything burnt on the PCB. Removed the PCB where the controls are and again no sign of burnt markings anywhere. So, at the start of all this I tested the compressor across the pins and got readings of 7.8, 4, 3.8 ohms. Days later, after receiving the new parts and installing them and still getting no operating compressor, I retested the compressor and got 0.01, 0, and 0 ohms for readings. Did I kill the compressor some how? the only other thing I can think of is reversing the wires on the startup rely, but I'm pretty sure I replaced them the way I removed them, but you never know.
Would this hurt anything if I switched the Pink and the blue wires? Any help at all would be greatly appreciated. Thank you in advance.
