- PFSS5RKZASS
- GE
- 6-10 years
The water line on my french door keeps freezing up. I noticed that for some of the GE side by sides, they've issued water line heaters that are installed just under the dispensing tube (more or less). Anyone know if GE has issued some kind of heater element retrofit kit for the PFSS5RKZASS water line? I think it could already have a built in heater for the dispenser, but I'm not sure if I'm understanding the service manual correctly. Does anyone have any tips here?
Just reviewing the service manual and parts lists, it looks like there's a duct door heater that can be purchased. I can check the resistance on this part to see if it's not operating, but either way I don't believe that part impacts the water line. Aside from that I notice that the service manual mentions a "Fill Tube Heater" on pg. 63. It has the notes "Replaced as door assembly" which isn't encouraging, and "Fill Tube heater will be on after water valve activation or when ice is dispensed." I assume this fill tube refers to the water dispenser tubing. Haven't quite worked out how to access the connectors for this to check the resistance. It's a little ominous that replacing it requires replacing the door assembly.
So, I've tried just leaving the paddle actuated to see if this might defrost the water fill tube without any luck (just going off the language above that the fill tub heater is on after water valve activation). My only solutions so far involve taking apart the ice dispenser and making sure any built up ice is cleared off, and also using a syringe to basically give the water tubing a hot water enema.
