GE Profile PVM1870SM1SS Fan Always Runs with Door Closed
gscott
NC
PVM1870SM1SS
My OTR microwave fan runs whenever the door is closed. The unit heats properly, but after the cook time is complete the fan continues to run and the oven interior light stays on. The only way to shut the fan off is to leave the door open.
Thanks. Greg.
Let us know what you find/see.
Stevew2023
New Jersey
I realize this is an old post but my GE Profile OTR microwave just started doing the same thing. Fan runs when door is closed. No heating or turntable, just fan. Stops when door is opened. I checked the 3 door switches and they all have continuity. This happened after I inadvertently left the door open for an extended time (couple of hours). Any help is appreciated. Thanks
And they open and close properly when the door is opened or closed?
Stevew2023
New Jersey
A little hard to tell but they seem to. I did notice that if I wiggle the door up a bit the fan stops but the unit is still non responsive to controls. I've also reseated all connections on the main board.
That should point to an door switch/door switch mechanism, door switch wire, door switch key issue of some sort.
If all above checks ok, the board is the prime suspect then.
Stevew2023
New Jersey
The door has a little play in it and it. Looks like when I close it and lift on the handle the top switch disengages, but then none of the controls work, as if the door were open.
With door closed some buttons work, some buttons don’t.
Since it is 9 years old I’m considering just replacing it rather that spend a few hundred dollars trying to repair. The new Profile model is only $540. What are your thoughts?
Thanks for your help.
Most don't last part 9 years any more, so replacing it might be the best idea.
Most all come out of the same factory's....what ever fits your price range and needs will do fine.
