GE Profile Refrigerator PSS26NHSAWW Freezer Warm, Refrig OK
tperk100
Virginia Beach, Va
PSS26NHSAWW
Model # PSS26NHSAWW, Serial # GH411060
Yesterday my freezer monitor alarm sounded. The freezer was 28 degrees with refrig at 37. I had loaded up the freezer (with FROZEN food) about 4 hours earlier. I immediately thought that I had left the door ajar, but the door did not look or feel like it was open. So I opened it, made sure there were no obstructions, and closed it. The freezer temp started dropping, so I guessed I had the door cracked open a little somehow and now all was OK.
3 hours later the alarm sounded again. Temps were same as above. Now we think the freezer is defective. We emptied the freezer. This was about 9 pm last night. At 7 am this morning the freezer temp is ZERO!! I’m reluctant to use it at this point because I suspect something is intermittently wrong with it. I guess I’ll leave it empty, and watch temp for a few days.
Would like opinions / suggestions.
Thanks much
Do you hear the fan in the freezer running?
Do you see frost build-up on the back inside the freezer?
When the alarm sounds is the refrigerator compressor and fans running? Or is everything dead silent?
tperk100
Virginia Beach, Va
Thank you for helping me.
I don't remember if fan and / or compressor was running, but both are running at least some of the time to get to zero degrees this morn.
I did look for frost and saw none.
The alarm is aftermarket with bluetooth sensor in freezer. Its only relationship to freezer is that it monitors temps.
Update - at 0700 this morn it was zero. At 1000 it was 23. At 1300 it's back to zero. Door has not been opened since yesterday. It seems to me this is too much of a temp swing to say its operating properly.
What do you think?
Tom
That's very odd Tom, I have no clue what's going on here, never seen anything like that before. Its best to have a GE tech. come out and see what's going on.
tperk100
Virginia Beach, Va
Thanks. I think I will let it run empty for a week or so before I might put anything back in it. My monitor records high and low temps, so we'll see what it does. Maybe I'll get a "hard" failure that will be a lot easier to troubleshoot.
Regardless, I think I've gotten my money's worth out af a scratch and dent refrig bought "on sale" 16 yrs ago.
Yes Tom, you are absolutely right, the hard failure is the best failure to fix this problem properly.:)
Intermittent problems are the hardest to nail down.
tperk100
Virginia Beach, Va
Been over a week and freezer temps swinging from -7 to +3. Great!
Now what's Murphy going to do when I load it up with food?
Thanks for your help.
CASE CLOSED!.......(for now)
