- PSS29NGMDBB
- GE
- More than 10 years
I was having the same problems as everyone else. Freezer temps would start going up so I would unplug it so it to defrost, then it’d work again for a while. I cleaned the condenser coils and rest of back of fridge, but still had problems. I finally replaced the following parts: (1) defrost heater & bracket assy {the bulb was bad} (2) the temperature sensor (3) the defrost limiter thermostat and that’s when I began having the problem above. I then replaced the temperature sensor board and the problem remained, so I finally gave in and replaced the main control board. Now the temps remain as stated above and a fan runs continuously. The compressor is working (kicking on & off). Could it possibly be stuck in the defrost mode? Would love suggestions? Thank you.
