GE PS950SF3SS Control Panel Unresponsive with code not listed in manual or in forum after power outage
epbobcat
KY
PS950SF3SS
Following storm related power outage the range control panel displayed the message pictured below. It was unresponsive to any command touched on the control panel, including after turning off the power for 60 seconds and turning it back on. About 30-60 minutes the control panel began working normally. Two days later the panel stopped responding agan NOT following any power outage or other obvious power input issue. The same message is again displayed. The issue does not respond to turning of the power as described above. It has not resovled after 60 minutes as it did the first time it occurred.
I have not been able to find any discussion of this code or situation.
  • IMG_7186.pdf
Without that error code being listed in the tech data sheet or service manual we have no way of telling you what error code that relates too.
You have 3 circuit boards on your model: https://www.repairclinic.com/ProductDetail/2152870?c=13
It could any one those three that is causing it, and you can see they are expensive, so its best to contact GE to come out at 1-800-432-2737 to determine which you need.
Anytime Ken!
Let us know what they find if you can please. Thanks!
