GE Range JB645RK4SS hot cooktop light on
wongtong
us
JB645RK4SS
Hi all,
Only 1 of 4 burner still function. And the hot cooktop light is always on.
If I remember correctly 1 larger burner went out after the cooktop light stay on all the time. Then the second and 3rd burner stopped working within a few months range.
Now only one of the smaller burner still work.
I did a continuity test on all the elements and all still good.
I don't know how to properly test the thermal limiter.
Thank you
Thank you for the tech sheet.
Put on some protective glove and did a live test. Magically 1 of the other smaller burner it working again. Before the burner lit up I heard a click. Guessing the thermal switch closed and now send power to the element. Now I have a total of 2 smaller burner working.
But the 2 big burner is not working.
When I put the probe on 1&2 1&3 2&3 no voltage
When I put the probe on 1 on the element 2a on thermal limiter no voltage same as 2 and 2a
Did a continuity test 1a and 2a failed no continuity
Did a continuity test on the control knobs it passed
In Conclusion no voltage going to the 2 big burner. And the continuity test on 1a &2a on the limiter switch failed.
Does that mean the 2 big elements and thermal limiter need to replace since the continuity test on 1a & 2a failed?
What about the problem going into (before) the thermal limiter? What else could cause no power going into since the knobs switch continuity test passed?
