GE Refrigerator GSE25HSHJHSS freezer light out
cooler-TL
C-FL
GSE25HSHJHSS
I already checked switch, not the problem. ordered a light ( LED ).. what's the voltage at the connector suppose to be?
2017 / GE / GSE25HSHJHSS.
cooler-TL
C-FL
I got like 69.5 V... Just to be sure 120v where the light plugs in? if so, I guess I need to check the transformer? will it hurt to leave it as is? I don't really need the light.
Remove the light so it's not getting low voltage. Every time I've seen this issue it's always been the light switch. You can check the voltage at the board. J11 (brown) goes to both light switches and the RC light is working. Measure the voltage from the brown wire on the light switch to Neutral (orange) from supply voltage. Then measure from the red wire on the switch and see if it's the same.
cooler-TL
C-FL
OK will try it.. By board, do you mean the control board of refr.? Did buy a new switch both old and new bench tested same. yes, the reg . compartment light is working.. I will remove the LED light from freezer..
Sounds like a pinched or broken wire either between the board and the light switch (brown), the light switch and the light (red) or the Neutral side of the light
