GE Refrigerator GSS25 Water dispenser in door routing
WillyW
ABQ
GSS25
I bought a used GSS25.
The previous owner was working on it....
The icemaker functions perfectly, besides needing a new auger.
Water in the door does not function.
I have two lines coming from internally.
How are the lines run from the single point of the solenoid in relation to these two lines?
Y fitting to both?
I do need to open her up and cut a coil off the cooling spool because of deterioration.
When I got her, there were brass fittings on a short line from the solenoid and on the left most line coming internally.
Right internal line had no fittings.
I reconnected the left line to the solenoid and when actuating the water in the door, water comes out the right internal line onto the floor.
Hi, GSS25 is just a partial model number, we would need the complete model number.
Click here: Appliance Parts
You have a water inlet valve where the water comes in from your house, that has a dual solenoid, one solenoid for the water dispenser and one solenoid for the ice maker.
