Ironbar
- PFSF6PKWBWW
- GE
- More than 10 years
I have a GE PFSF6PKWBWW. Very old refrigerator but it sat in storage many years so I thought it would still run fine. Unfortunately it does not.
The freezer on the unit cools but it does not freeze the top tray. It seems to hover around 34 degrees. The bottom bin seems to at least stay below 32 degrees but not by much. If you place water in the top tray it get slushy but does not freeze solid.
I have done the following:
1) checked the resistance of the thermistor at room temperature and the resistance is correct (need to double-check at freezing temperature)
2) checked operations of both freezer evaporator fans - they are both spinning
3) check to make sure the evaporator is not frozen over - it is not, it seems to barely have any frost on it
4) reset panel and checked ran through diagnostics - nothing is showing in error
The display panel shows the freezer achieves whatever temperature I set it to. i.e. if I set it to -4 degrees, after an hour or so it reports the unit is at -4 degrees.
So, my questions are, where does the display panel get it's temperature from? Is it reporting the thermistor at the evaporator coil or the thermistor in the ceiling of the freezer? Any idea what would cause this issue?
