GE Refrigerator PFSS5RKZHSS Air duct motor runs continuously for icemaker
oldtimer73
NJ
PFSS5RKZHSS
Recently installed new air duct motor for GE ice maker. Ice maker unit is working but I have noticed the air duct motor runs continuously I do not know if that is normal or it should cycle on and off either by a sensor or motherboard. Appreciate any info on this issue since I do not think motor should run constantly.
OK, the fan will turn off when the compressor turns off or if the machine is in defrost mode. The fan's duty cycle is 100%.
Ice Hardening mode: Fan on high speed, while compressor is on.
Ice Storage mode: Fan on low speed, while compressor is on.
oldtimer73
NJ
Thank you for that information. I have heard the air duct motor running all day from 7am to when I go to bed at 1100pm.DOES THE COMPRESSOR NORMALLY SHUT OFF IN THE MIDDLE OF THE NIGHT? In that 1100pm -700am time frame? Ice maker is working-ok and refrigerator is operating fine. I am just concerned never hearing motor shutdown. Again thanks for your help
Refrigerators can't tell time and there's no clock in there anyways. The control uses the information from the sensors to know when to cycle off/on or start a defrost cycle. What settings are you using?
oldtimer73
NJ
Hi rick my normal settings for my freezer were-2 and fresh food section-38. I tried turning off entirely cooling operation from front door control which apparently worked since no air was coming from evaporator fan motor.
I kept it off for approx five minutes but to my surprise air duct motor keeps running. I then returned back to my original settings of freezer -2 and fresh foods -38 and frig returned to normal operation.
Puzzling I am glad refrigerator is operating ok just concerned air duct motor never shuts off hoping it will not take out main control board. Anyway again thanks for your help.
Setting either or both controls to OFF stops cooling in both the freezer and refrigerator compartments, but does not shut off electrical power to the refrigerator.
