FIXED GE Refrigerator PSCS3RGXCFSS dispenser not working
Timware2001
KS
PSCS3RGXCFSS
Hello, when we push through ice and water dispenser paddle nothing happens. More specifically when the water button is selected nothing happens, but when crushed or cubed ice is selected and pressed, it appears to intermittently short out the display as the lights turns of and the temperature displays go off and come back on for the side by side settings on the display.
The ice machine is still making ice, both the freezer and fridge still work without issue. I checked the connection below the freezer door and it appears fine. Really seems to just short out. Any confidence on what the root cause is and how to fix?
It sounds more like a motherboard problem.
Pull the refrigerator out from the wall, then unplug it. Then open up the metal access cover on the back cabinet of the refrigerator and behind that cover is your motherboard, look at it closely to see if you notice any burnt or discoloration on that board.
Here's the motherboard for your model:
WR55X10775 Board Asm Main Control
Timware2001
KS
Thanks Jake, nothing super obvious to me...only thing that's looks odd is these two chips have a pink and yellow splotches on them, but they don't look burnt up, any thoughts
Timware2001
KS
Also update, put the cover back on and its (motherboard area) clicking every 3-4 seconds. The display is going in and out with the clicking. Water ran from the dispenser for the split second it appeared to be powered
That pink splotch looks its melting the microchip on top, that's not good.
Replace the motherboard and you should be back in business.:)
Excellent Tim, glad to hear the new motherboard fixed it.(y)
