- GCF23KGWCWW
- GE
- More than 10 years
This GE side by side refrigerator model number GCF23KGWCWW had a defrost problem and I found the defrost heater part WR51X10055 was burnt out.
I defrosted the coils, replaced the heater, replaced the panel and put everything back and turned the refrigerator back on.
The control panel lit up showing temperature 0 in the freezer (impossible as it had been open to room temperature for hours and defrosted) and 65 in the fresh food (reasonable) but the refrigerator would not start.
The compressor did not run and the evaporator fan did not work when I pressed the freezer door switch to make the freezer think the door was closed.
I left the refrigerator (with both doors closed) and researched why it would not start.
Finally a couple of hours later I found the refrigerator running, the temperature showing reasonable numbers, and it cooled down to the set temperatures within a few hours.
It has worked fine for a couple of days now.
Is this delayed start normal? Is there a way to help it start? Is this an indication of a failing overload/start relay?
I would appreciate any help.
